Old 05-27-2012, 04:29 PM   #31 (permalink)
luv2spd's Avatar
Jakobnev, I thought about the sharper separation too now that the Airtabs are installed, I wish we could have somebody test this in a wind tunnel, maybe the MythBusters will test these one day
Old 05-27-2012, 06:12 PM   #32 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
The inventor of air tabs did. It was on a hatch back and he reduced drag by over 4%.
One thing you need to remeber is that these were designed to go on semis which will have a thicker boundry layer. Because of this they are taller than they need to be for most applications of a car. This means that they will generate more drag and can easily offset any gains
Old 05-27-2012, 06:56 PM   #33 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
What if you just put some ordinary round magnets on your car instead?
Old 05-27-2012, 09:48 PM   #34 (permalink)
sid
grayranger - '10 Ford Ranger XL 2 door supercab
90 day: 30.76 mpg (US)
I don't know. Try it. It sounds simple and cheap enough. My gut feeling though is that it will hurt the aerodynamics. But, who knows?
I get a lot of those flat flexible magnets with advertising on them free. I think they are intended as refrigerator magnets. They are simple to cut with scissors. They might be worth trying. You could try almost any shape you want, if you can cut it.
2010 Ford Ranger, extra cab, 2.3 liter
http://www.stonemarmot.com
Band's latest song/music video "I Sing Along"
Old 05-28-2012, 12:10 AM   #35 (permalink)
Drive less save more
ecomodded's Avatar
90 day: 60.42 mpg (US)
Put them on your dashboard and you will SEE a gain
(a small weight gain)
I personally like the shark fin style air tab which is what they use on aircraft. The aerodynamic drag of these will be minimal, having a very narrow profile they are designed for high speeds.
Like the 747-400 has a cruising speed of Mach 0.85 (567mph). It's maximum speed is Mach 0.92 (614mph).
I hope not to give a wrong impression of the effectiveness of these at lower speeds, in practice the airplane wing air tabs allow a plane to take off sooner as well as using less hp which= fuel. the 747 takes off at 120 mph. Smaller planes with lower take off speed also use air tabs, the 747 was just an example.
Save gas
Old 05-28-2012, 12:19 AM   #36 (permalink)
Del Slow - '94 Honda Del Sol Vx
90 day: 42.31 mpg (US)
Lancer Evolution
Old 05-30-2012, 07:12 PM   #37 (permalink)
heading for 40
redorchestra's Avatar
Hong Kong MTR - '98 Bombardier/ nee Adtranz A-Stock 5 paired doors
90 day: 102.63 mpg (US)
I fabbed small aerotabs to fit on magnetic sheets. I was a bit afraid that they would fly off but so far so good! good to 110 km/h
I dont know if they have any effect on MPGs, but I did notice one thing.
I drive a hatchback, and when it rains I usually have to run the rear wiper. Today with the airtabs my rear window stayed completely dry.
I personally doubted the airtabs would do anything, but now i am wondering. It definately changes the wind patterns at the rear.
I would love to tuft test it, but I dont like to drive just to test.
this is just my observation
does my sig work now?
Old 05-31-2012, 04:17 AM   #38 (permalink)
ecomodded's Avatar
Here is tuft test video of Vortex generators at work
At 8 min the wing has full vortex generators at which point the stall speed changes drastically from 58 kt to 38 kt.
Those are the style of VG's I want to paint and stick to my car. They look good, in my eyes, but more important they are proven to work.
Save gas
Old 05-31-2012, 11:45 AM   #39 (permalink)
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
flight does not equal or represent flow on a car on the ground. Just keep that in mind when looking at that vid. The air passing under the wing has a lot to do with how that looks, and you also are not in the business of generating lift with your car. Lift = drag.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
The Following User Says Thank You to skyking For This Useful Post:
ecomodded (06-02-2012)
Old 05-31-2012, 12:25 PM   #40 (permalink)
I only had time to watch half the video, but found it to be very interesting.
air tabs, fixture, testing, van
