1998 S10 2.2L 2wd aluminum driveshaft swap
I am considering swapping my original driveshaft with an aluminum one. I found one off a 2001 S10 online. It looks as though the length is perfect. However, I just wanted to see if any of you could inform me of other potential problems I may run into with the swap. I am checking now to see if the donor truck is 4wd or 2wd. Would that make a difference with the driveshaft? Also my truck is not an ext cap so I have a 1 piece driveshaft.
Thanks!
