Originally Posted by mechman600
Easy. Put ICE in gear. Step on EV go pedal. EV motor turns driveline, moves truck and rotates ICE (all at the same time) to start ICE.
OR
Step on EV go pedal. Once vehicle is moving, push clutch & put ICE in gear. Dump clutch to start ICE.
Yeah, looks easy. Especially, when it's in the garage or tight space without runway, as i wrote "if you have to start the diesel for whatever reason".
