Originally Posted by Sporty Modder
I dont mind the road noises  it smells better in the car now +I can fix the little rust I found
This is always the best part about not having an interior, carpet many times helps rust along, the old cars you could see it and fix it, new ones its covered up and kept damp, I would "fix" the rust then put a coat of rhino liner or something similar on both sides, if you need to patch a hole the old black fiber roofing cement works wonders.
Good Luck
Ryan
