Old 06-01-2012, 07:21 PM   #4 (permalink)
oil pan 4
When you buy a non greasable U-joint its made of top quality materials, or else it would only last 50,000miles.
When you buy a run of the mill greasable U-joint they are usually lower quality because its assumed they will be greased.
You can get high end greasable U-joints but they cost 2 or 3 times as much as the cheap greasable U-joints.
The best, which is what I get are the high end spicer greasable U-joints.
I have an aluminum drive shaft for my camaro which I have not installed. I ebayed it and took it to the drive shaft shop for ballance and U-joint replacement, if I rememer right it cost about $120 for all that.
