Originally Posted by t vago
This will make the pumping loop look more like a triangle...
I wonder if this triangle would end up dipping lower to right side to make up for the lack of vacuum when the intake valve first opens to achieve the same cylinder vacuum when the intake valve closes.
If so, this would end up giving you the exact same pumping losses as with a single throttle body.
