Old 06-02-2012, 04:34 PM   #46 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Originally Posted by mechman600 View Post
A bit of a side note. Unplugging the intake manifold temp sensor and installing a resistor to make the ECM think it's cold advances the timing on some engines and does wonders for mileage. I repeat: SOME engines. Cat engines: 100 ohms = indicated 7F. Cummins I'm not sure, but I could easily find out.
I can believe this. It's a cold start up feature. During cold startup (or extremely cold conditions) the ignition delay increases, thus the injection timing is advaced to prevent the combustion from occuring too late in the cycle. In extreme cases this late combustion can cause white smoke or misfire. The ECM is using the IMT sesnor to detect this cold condition.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
