Old 06-02-2012, 06:11 PM   #47 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by mechman600 View Post
On any of the engines I deal with (Cummins/Paccar/Caterpillar), intake heaters are only for cold startup. Extra heat for DPF is done with engine timing (...) never with increased intake heat.
On my PSA / FoMoCo 1.6L Diesel, the reported intake temperature (on a ScanGauge) will increase from it's normal 5-10 °C over ambient, to an actual 50-60 °C during DPF regeneration, so it's obviously a manufacturer's choice to do so.
I'm not too sure if it's a good choice though ...
Coolant temperature also increases a few °C during regeneration.
With 28-30 °C outside temps, I've recently seen coolant temps up to 95 °C
Normally it's only 79-83 °C , even during regen.
Thermostat is 81 °C.
