Old 06-05-2012, 09:31 AM   #88 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Originally Posted by nerdboy View Post
Just be prepared to explain to everyone who asks why your hybrid isn't hybrid.
Not a problem.
And I will also be prepared (in advance!) to explain how I managed to screw up the T.S.D. portion of the drive, which will likely sink any chances of placing well on corrected fuel economy anyway! That part sure adds an interesting twist to the event.
Hey Darin, I'd be curious about your opinion of my air dam which goes lower than the lowest underbody parts, but currently doesn't go particularly far down between on the lateral sides (between the front of the bumper and the wheels). Anything I should add/change?
If I'm understanding your description (more pics?), I'd encourage you to "wrap" the dam around the sides of the front bumper back to to the forward edge of your wheel arches/tires. (Basically, the same as the modified Insight, pictured.)
If there's a significant gap between the dam & the front tires, I'd wager flow along the side of the car would be more turbulent as a result.
