Originally Posted by chrisgerman1983
possibly? but its blowing smoke on startup and it never did before? I just assumed that it cleaned some gunk out that was stopping the seals from leaking? I used it in the intake and the oil, and then did an oil change. Could thinner oil cause leaks?
If right, then the sea foam helped you diagnose a problem needing attention. If wrong, then you have still correctly noticed a leak needing attention. The sea foam was more like a diagnostic tool than cause. I don't imagine the thinness of the oil could cause instant leaking, though maybe long term if it increases wear on parts. I wonder what others with more experience think.
