Old 06-07-2012, 09:00 AM   #83 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by renault_megane_dci View Post
When my bike starts to wobble, I find it useful to let go the throttle a little and hold the handlebar using only my right hand as I red somewhere that the wobble gets worst when one try to compensate.
I did the same on the Beamer before the screen was removed - drive it single handedly.
Tensing up is no good on a motorcycle.
Compensation can indeed make matters worse - driver / pilot induced oscillations have caused crashes before.
my rear tire tends to randomly lose pressure.
Have you checked it for a puncture (with the object still in the tyre) ?
Or have you had it repaired after a puncture ?
These can start leaking as you wear the tyre down - been there, done that, wobbled about a bit as well
When none of the above : check the valve (balloon and rubber band) ; check the wheel itself for small damage where the tyre is seated next time the tyre is taken off the rim.
