Old 06-07-2012, 01:19 PM   #9 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
it gets about 14% longer range from a battery pack that is about 16% smaller.
It may also be getting more range (partly) by using a smaller "buffer" in the pack than Nissan does with the Leaf. If I'm not mistaken, most EV makers spec a pack that is larger than actually used in a "full" charge/discharge cycle to prolong cell life. I could confirm this by doing the math, since we know pack size, range & Wh/mi for each car, so we could calc how large the "unused" buffers are.
As an example of "buffer tweaking": the 2013 Volt has slightly longer EV mode range than the 2012 Volt because GM enlarged pack capacity slightly, changed chemistry, and reduced the "buffer" size.
when you put the Fit EV in economy mode -- you get free wheel coasting; and only get regenerative braking when you press the *brake* pedal*. Sounds like the EV I want to drive!
I agree - coasting beats regen. But I'd also like a customizeable pedal, as Tesla is offering in the Model S. Sometimes, 1-pedal driving would be convenient (eg. stop & crawl).
Honda needs to build as many as they can sell! And they need to sell them everywhere; not just in a few states.
Unfortunately, they won't sell any to anyone. It appears these are lease & crush compliance cars, just like their last EV that was publicly available (the Honda EV+).
Lease return Honda EV+ in line for the shredder at a junkyard. From Who Killed the Electric Car.
