Thread: trailer aero
Old 06-09-2012, 10:11 AM   #16 (permalink)
skyking
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
Originally Posted by euromodder View Post
Why would it ?
The trailer tilts around its front axle.
Removing anything from behind the front axle, will increase tongue weight.
If the intended load allows for it, move the fuel tank aft over the wheels.
If possible at all, move it to be near the rear axle.
taking rear tires off removes that force upward there. pivoting around the remaining axle, this acts to remove tongue weight. Leaving the rear axle in place without tires, removes even more tongue weight.
This of course lowers the carrying capacity, and might induce less than friendly tracking, bounce in the bumps, etc.
Typically, two axles track nicer, have less tendency to bounce, less tendency to lift and lower the tow vehicle (TV) because the tongue weight is more stable. Downside, more parts to replace, tires, scrubbing during tight maneuvering.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
