Old 06-09-2012, 10:26 AM   #13 (permalink)
MPGranger
Whitey - '10 Ford Ranger XL
Pickups
90 day: 33.74 mpg (US)
Hershey - '13 Nissan Altima SL
90 day: 28.68 mpg (US)
Midas - '10 Toyota Prius two
about the atkinson cycle engine. I thought the big deal with it was that the connecting rods also cycled so a cylinder had a combustion event every 360 degrees of crank rotation. (Versus the 720 degrees with the otto cycle) But atkinson cycles are low on power/high on efficiency since the full compression isn't fully used.
and a miller cycle engine leaves the intake valves open until the combustion event so a supercharger keeps packing the cylinder. So the static compression ratio is useless here as well, and so is the dynamic (since the valve is open almost to top dead center)
Check out my facebook page, if you feel like watching my progress.
http://www.facebook.com/pages/MPGran...007268?sk=wall
