Originally Posted by MPGranger
about the atkinson cycle engine. I thought the big deal with it was that the connecting rods also cycled so a cylinder had a combustion event every 360 degrees of crank rotation. (Versus the 720 degrees with the otto cycle) But atkinson cycles are low on power/high on efficiency since the full compression isn't fully used.
Atkinson is still a four cycle engine with power stroke every 720 degrees.
and a miller cycle engine leaves the intake valves open until the combustion event so a supercharger keeps packing the cylinder. So the static compression ratio is useless here as well, and so is the dynamic (since the valve is open almost to top dead center)
Increased static compression ratio = increased expansion ratio (regardless of intake valve timing), so static still means a lot when it comes to efficiency.
