Drafting !!! Haha, at the speed limit, she'll never pass a car around here let alone find a truck to draft ... no she is not that brave especially with the baby in the car .. I can't even get her to roll the windows down in the city ... yet.
As far as something to measure I use a shot glass measuring cup made from pyrex as Acetone melts plastic. Go to your local grocery store and look in the baking isles they have to have all kinds of standardized measuring cups most made from pyrex because the are microwave safe.
Now I will be doing another such experiment this week as I drive to Tulsa. I'll be in a three car caravan with 2 xB's and 1 tC. I plan on taping up the xB i'm driving for better aero, over inflate the tires and run Acetone and compare those results against the other xB and see what turns up. Again not as scientific as I'd like but we will be traveling together and I will be working out a system to share each others draft for the same amount of time to try and keep the numbers consistent. Both owners know what their current tank ranges are because I have asked them to monitor it prior to the trip. Should be fun .. I should convert a couple more non believers after this ..
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
