Now the good news is if 1mL works, you can creep it up in qty until you plateau then back off. I keep reading 3 oz is the magic number but that is 9 times the amount I am using now and just seems like a waste of Acetone, but I' sure others will try this and document the results a bit better.
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
