Old 06-09-2012, 10:25 PM   #14 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Originally Posted by ksa8907 View Post
Once you're rolling, you dont really "need" the clutch at all. Just match the input and output shaft speed and it'll slide right in.
Going that route you are still better off using the clutch, driving without the clutch pedal like that is only a good skill to have for those very rare times that the linkage stops working, do your best to match the engine speed when shifting and you can make a clutch last 1,000,000 miles, shift without using the clutch and you can wear a transmission out in 10,000 miles if you aren't good at it and the clutch is the cheaper part to replace.
