Old 06-10-2012, 05:51 PM   #18 (permalink)
metromizer
Originally Posted by ERTW View Post
Yamaha 5 valve tech will not knock - 93 octane with 13.5:1 cr! The corvette LT5 was said to run fine on 87 octane with 11:1 cr.
A lot of recent engineering has gone into homogenous charge, better mixing of the fuel and air within the combustion chamber. That, coupled with better 'active' fuel/spark controls I think is what allow today's engines to use higher compression ratios with relatively low octane fuels.
