Old 06-11-2012, 01:17 PM   #20 (permalink)
Lessendz
Have, Give, Receive
Lessendz's Avatar
more like Days..
and depending on local conditions
it may even attract water into the fuel itself..
we have higher humidity here in Hawaii..
Although this didn't seem to be as much of a problem in dry area's of the mainland..
we road trip'd from Vegas to LA on a blend of 8%ethanol & 7% methanol
Over 15% total alcohol in a Nissan 350z (enthusiasts model)
and burned about 1/4 less fuel on the trip cruising @ 90mph thru 100deg weather!!
Although the alcohol evaporates out of the blends rather quickly..
the Toluene left behind turns the gasohol into a high aromatic/octane gasoline
Engines equipped with individual coil pack ignition will usually automatically start make the necessary adjustments on its own..
The Following User Says Thank You to Lessendz For This Useful Post:
Christ (06-12-2012)
