Originally Posted by JRMichler
If you want to grab a truck bumper with a magnet, do it right. Use an electromagnet so you can turn it off.
McMaster-Carr ( McMaster-Carr) has a whole page of electromagnets. Try the P/N 6598K315 for a start - fits in the palm of your hand and only draws a little over 2 amps for 600 lbs pull.
The trick is to get close enough without the driver seeing you coming. Can magnets make your car invisible, too?
That's actually quite an idea...
<40w being up to 600lbs of weight reduction (circumstances approving) is actually quite a gain.
