06-10-2012, 06:44 PM
#251 (permalink)
Luv it Frank, I worked in a parts store and then as a quality inspector over the years. Last job was in a research lab. One of my favorite quotes is, "The customer is always right until politely shown otherwise." ![Wink](/forum/images/smilies/wink.gif)
06-11-2012, 01:58 AM
#252 (permalink)
Moderate your Moderation.
Pasta - '96 Volkswagen Passat TDi 90 day: 45.22 mpg (US)
Originally Posted by Piwoslaw
Who cares about the magnets? I was thinking about the aero advantage of drafting! ![Stick Out Tongue](/forum/images/smilies/tongue.gif)
I'd be trying to pull a Fast and Furious on the truck. I <3 magnets.
06-11-2012, 01:35 PM
#253 (permalink)
If you want to grab a truck bumper with a magnet, do it right. Use an electromagnet so you can turn it off.
McMaster-Carr ( McMaster-Carr) has a whole page of electromagnets. Try the P/N 6598K315 for a start - fits in the palm of your hand and only draws a little over 2 amps for 600 lbs pull.
The trick is to get close enough without the driver seeing you coming. Can magnets make your car invisible, too?
The Following User Says Thank You to JRMichler For This Useful Post:
06-11-2012, 02:36 PM
#254 (permalink)
aero guerrilla
Sure, if coated with unicorn droppings.
06-11-2012, 11:15 PM
#255 (permalink)
That's actually quite an idea...
<40w being up to 600lbs of weight reduction (circumstances approving) is actually quite a gain.
06-12-2012, 09:20 PM
#256 (permalink)
My truck has about 100 lbs of drag at 60 MPH, so the 600 lb pull electromagnet should hold quite well. The drag would actually be less if drafting that close.
Poor man's autopilot - get close, turn on magnet, shut off engine, go to sleep. Just need a unicorn to deal with the truck driver.
MTA: Hey, wait. This could actually work. Does that get me kicked out of the Unicorn Corral?
06-12-2012, 11:03 PM
#257 (permalink)
Drive less save more
It doesn't work that well you can stay
but your truck can go, Love that cap you put on it.
Save gas
09-11-2012, 04:15 PM
#258 (permalink)
Tank - '76 Chevy El Camino Classic 90 day: 25.89 mpg (US) Sabrina - '91 Mercedes Benz 190 E 90 day: 37.07 mpg (US) Angel - '88 Mercedes-Benz 420SEL Last 3: 23.01 mpg (US) Quicksilver - '04 Mercedes-Benz CLK55 AMG Cabrio
OK i haven't been on here in forever but WHAT is he freaking talking about? How would magnets even work? i don't understand the concept
![](http://ecomodder.com/forum/fe-graphs/sig3408a.png)
Tank:
(No actual EPA numbers for car just used F/E numbers when i first got it)
09-11-2012, 04:20 PM
#259 (permalink)
Wiki Mod
thats the problem there is not any reason just that magnets are cool (and people have not idea how they work) and people believe anything with "saves gas" on it.
quack products and the science does not work.
09-11-2012, 05:43 PM
#260 (permalink)
Domman56, This thread is here because I tried a set of magnets on my car and they increased my milage as described earlier. To check results I tried them on my other car and similar results occurred and still have increasde milage for the past few years. I don't know why this happened. That is why I asked for help in duplicating the experiment.
I think the fuel is affected to some extent and caused the ECU to go to an economy mode. That's my theory. An engine analyser would need to be hooked up to monitor changes to ECU settings to verify if that is the case.
Other than that I am unable to give any other opinion.
