Old 06-14-2012, 12:47 AM   #3 (permalink)
mwebb
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
stoich , 14.64 to 1
while i was not graphing specified lambda
i believe
the system was at lambda of 1
14.64 to 1
this system can deviate from lambda of 1 while in fuel control
"lean burn" so to speak as can most systems that have / use
front AFR sensors
which is just about everything after the mid 2000 s
over 1400f .
http://ecomodder.com/forum/showthrea...tml#post253935
The 2 high temperature points on the A/F scale are some where around 13.2: and 15.7:1, one of those is the higher of the 2 but I am not sure which one.
These areas seem to be avoided by OEMs and hotrodders.
