Old 06-16-2012, 10:07 PM   #18 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by SmellyCat View Post
Update, TJTS1 is right. I was squeezing 25 mpg out of this pig with the alternator and 25mpg with out. I am so Bummed. It really seemed like a good Idea. I will try a switch on the Alt hot wire to see if that does anything next. Cheers. SC
Without really controlled ABA testing, you really can't know for sure the results. You'll want weather, road, temp, throttle, speed, and route conditions all to be the same at minimum. Then there is the state of how warm the engine and tires are... the slightest changes in your throttling--imperceptible to the driver--will alter results. I hope by "the hot wire" you don't mean the alt's output wire to the battery... somebody here wrecked an alt that way, fried it, IIRC.
Sorry for the bummer... keep up the efforts... some work some don't, you know? Good luck!
james
