Old 06-19-2012, 09:08 AM   #56 (permalink)
Varn
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
I wonder if your lack of speed is from the gearing. Probably the engine governor is set for about 3600 rpm. You might be able to modify your governor but then the engine will be above the torque curve.
Maybe putting big tires might help you alleviate some of the gearing issues.
Noah Webster, 1787
