Old 06-26-2012, 11:11 AM   #29 (permalink)
MetroMPG
90 day: 57.73 mpg (US)
One more point I'd add to the "why following closely is generally a bad idea" column of the debate leger: when you follow anything too closely (intending to draft or not), not only do you diminish your forward vision (which is fine, if you like a life full of surprises), you now must brake as soon and at least as hard as the lead vehicle does. (But probably harder, after adding in your reaction time.)
Big deal, you say?
Now consider the usual tailgater behind you, and see how you have lost the opportunity to anticipate & respond to speed changes more gradually and on your own terms. Slowing gradually is a basic defensive technique for reducing the chances of getting rear-ended by your tail-gaiter.
