I'll throw out a caution for people with older engines. In 2006, Toyota put out TSB EG018-06, which changed the recommended oil for certain 2006 engines to 5W-20W, and for other 2006 and 2007 engines to 0W-20W. Owners of older Toyota engines should continue to use the engine oil recommended in their owner manuals (typically 5W-30W for 2004-2005 models). Apparently, the older engines don't have adequate bearing smoothness/clearance to use the thinner viscosity oil.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
Mean Green Toaster Machine
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
