Old 07-03-2012, 04:05 AM   #81 (permalink)
redpoint5
90 day: 38.47 mpg (US)
Originally Posted by JacobAziza View Post
No forced air, the heater is installed on an exterior wall and the exhaust only has to travel a few inches before venting outside.
Thanks for taking the time to explain your setup. My gas water heater is likely 17 years old, and I'm considering replacing it with a tankless. I didn't realize there were more affordable models until you provided the Ebay link. Do I have to install on an exterior wall, or can I just use the existing ducts that feeds my current gas heater? I wouldn't want to install on an exterior wall because it already takes ages for hot water to get to any of my low flow faucets.
I too set my temperature at just the setting that is comfortable to take a shower in. It's a great idea and should combat the problem of temperature changes when other faucets are opened.
