Old 07-05-2012, 04:31 PM   #7 (permalink)
HilseeJ
TBA - '07 Honda Fit
Originally Posted by GRU View Post
install a kill switch to turn off the fuel injectors. there is plenty of info if you do a search on how to do that
That's easy to say, but sadly I'm going to have to disagree with you here. I have found very little info with easy to take steps to install an injector kill switch. Especially when there's no injector fuse.
No one has taken the time to do a good write up as far as I've seen.
The Following User Says Thank You to HilseeJ For This Useful Post:
MPGranger (07-06-2012)
