Thread: Evans Coolant
Old 07-05-2012, 10:15 PM   #10 (permalink)
mikehallbackhoe
mikehallbackhoe
honda crx - '84 honda crx 1300
90 day: 55.83 mpg (US)
I use it in my backhoe. the other day I replaced my head gasket , perkins turbocharged 4 cyl. after getting it back together, I was chasing down fuel leaks, so I removed the fan belt so I could safely stick my head in for a closer look. . the next morning I was in a hurry to get to work, and forgot to install the fan belt. after working for an hour, the oil got so hot, it boiled out of the crank case. I let it cool down, installed the belt, replaced the oil, and fired it up. no smoke, it didn't seem to hurt the engine at all. I am sold on evans coolant. as a side note, they don't recommend a 0 psi cap, all that is needed is a few pounds to keep dirt out of the system.
