Originally Posted by HilseeJ
That's easy to say, but sadly I'm going to have to disagree with you here. I have found very little info with easy to take steps to install an injector kill switch. Especially when there's no injector fuse.
No one has taken the time to do a good write up as far as I've seen.
Go to the DIY / How-To section and scroll down a little. I looked only at the first page and saw two write-ups on Honda cars getting a kill switch. They are not likely to be exactly the same as your car, but they are still Honda cars. that means they probably have the same basic design. A side benefit to scrolling down and searching this way is finding items you never even thought about.
AFAIK, some injector fuses are located in a fuse block under the hood, not in the passenger compartment. Don't be discouraged.
