Old 07-06-2012, 06:19 PM   #10 (permalink)
Weather Spotter
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
well I bought a roll of aluminum flashing to use as a building material. $35 for a 14" by 50 foot roll. I also have some wood I will bend into a curve to use as the frame, if I can find a good mount point.
At this point I am thinking of going flat from the underside of the engine belly pan to front of nose. then curving it up to match the hood and just below the lights. Some place I will put a grill opening that is ducted to the radiator. It will also be remotely operable
How far out should the nose go?
