Old 07-07-2012, 04:30 PM   #414 (permalink)
3-Wheeler
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
Originally Posted by sheepdog 44 View Post
I intend to do a project on my Insight based on this thread: http://ecomodder.com/forum/showthrea...ail-21455.html but it will be based on the shape of how you built your boat tail. The first build might be an agressive looking Kammback like i beleive "Kims CRXHF" if i'm correct; to test the durabilty of the structure. But will evolve to a full boat tail.
Do you know of any mounting points underneath the back of the car where i could attach two beams made of wood for the underbody support structure of the tail? It would have to allow clearance for the bumper as i do not intend to remove the stock plastic bumper? It would have to be an easy way to attach the two side structural beams cause i cannot weld. Lashing maybe?
That is the final piece i need to figure out in the planning stage.
Sheepdog,
Take a look starting at:
http://ecomodder.com/forum/179658-post2.html
.... and read through the text and pictures and study carefully.
There is hopefully enough information there for you to duplicate my mounting system in wood.
Jim.
