I use it in my F350 in conjunction with a 203 degree thermostat.
Tried the "zero pressure" cap but it made the truck smell like glycol, so I went back to the regular cap.
If you thoroughly dry out the system it will never corrode (from the inside at least).
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
