No pics today. Lots of little things; clutch cable, throttle cable, wiring, fuel plumbing, hood latch cable, connected starter signal and tested(no magic smoke and it did crank), coolant plumbing, vacuum plumbing, and made a list of small things still needed.
Almost forgot. I have access to a clamp on fuel pulse sensor that I will test with the MPGuino once running. A bit pricey from Mac tools, ~$200 just for the clamp. Might have to spend the long dollar if it works.
Reason: Memory lapse
