So far after the valve cover gasket replacement there look to be no more leaks.
Todays project involved:
Removing the air silencers
new FRAM air filter
spark plug replacement with Autolite AP64s(not indexed because it was getting dark)
1oz of regular Sea Foam in each cylinder while spark plugs were out and Deep Creep
cleaned TB using carb cleaner and Deep Creep
distributor cap and rotor replacement
