Old 07-10-2012, 02:12 AM   #6 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
Been alt free since joining. It's what got me here.
Cars pull between 20-50 amps and more at 14.5 volts. Alternators are at best 45%* efficient which means you can double the watts they draw off the engine. ~ 580W (.77hp) to 1450W (1.95hp) . Add the belt drag too. This draw happens every second the motor is running. At idle it can more than double your fuel consumption. At highway speed a small car needs about 9 hp to cruise. One hp is 10% of that.
Tell them to do the math. Alt delete makes a big difference.
*newer ones may be better but I have not researched this yet. An efficient electric motor is an expensive piece of equipment.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
