Originally Posted by euromodder
Make the EGR optional instead of blocked ?
With the turbo setup I have - that's not something I will be doing. It would help make it warm up though. I think I will go with a belly pan and some grill block stuff when the summer ends.
And I finally got some LRR tires:
I still need to get the rear spindle adapters from the machinest in order to install the rears, but the front is assembled - along with bigger brakes and axles to handle the torque of the TDI.
