Old 07-10-2012, 06:58 PM   #31 (permalink)
GTI TDI - '91 Volkswagen Golf GTI
Diesel
90 day: 61.23 mpg (US)
Originally Posted by euromodder View Post
Make the EGR optional instead of blocked ?
With the turbo setup I have - that's not something I will be doing. It would help make it warm up though. I think I will go with a belly pan and some grill block stuff when the summer ends.
And I finally got some LRR tires:
I still need to get the rear spindle adapters from the machinest in order to install the rears, but the front is assembled - along with bigger brakes and axles to handle the torque of the TDI.
Old 07-10-2012, 07:58 PM   #32 (permalink)
MPG Militia HMV-25E80+A
JethroBodine's Avatar
FrankenJetta D - '90 Volkswagen Jetta GL
Diesel
90 day: 64.35 mpg (US)
That's just candy, right there. Any semi used parts you want to get rid of, just let me know.
It is always very amusing how our imagination is put to the test when overcoming reality. Redyaris
Boat tail project
How to gently bump start during EOC
Old 07-11-2012, 12:57 PM   #33 (permalink)
Diesel
Most of what I have is to increase track width and bigger brakes... I think you are looking for the opposite - keep the wheels tucked under and the rotating mass light right? I bet rear disks would be a welcome addition though (less drag, lighter weight) maybe I have some spare rear disk stuff in one of my boxes... If I come across any and make it out to Bonneville I can bring them... anything in particular you are looking for? we still get a good MKII in the Junk yard out here occasionally.
And here is the thread with the full detail of the suspension work:
VWVortex.com - GTI TDI Gets a minor suspension overhaul, mostly VR6 & Boxster parts
Old 07-12-2012, 02:42 AM   #34 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Nice custom license plate too
Old 07-13-2012, 06:15 PM   #35 (permalink)
Diesel
Rear disk would be awesome I'd like to change over to vented disc in the front. I have solid now( came with it). Looks like I could get away with a new rotor and caliper, but I'm not sure. Also if you have any lowering springs( front and rear), let me know. I want to drop mine and raise it with air so I can drop on smooth roads and lift when it gets a little rougher.
I hope you do make it to Bonneville, we're starting to get a pretty good crowd. I want to see that baby run the mile.
Boat tail project
Old 07-13-2012, 06:50 PM   #36 (permalink)
Diesel
Yeah - If you are interested in MPG over everything else, stick with the tiny front brakes and step up to vented to allow for better fade resistance. Anything bigger starts to get heavy real fast. I'm sick and weighed all the suspension parts... Vented fronts should easily keep up with that 54hp diesel too.
And I really do hope to make it. I'm currently swamped with trying to get the rear end done so I can get the LRR tires on the rear before my 2-week road trip to Colorado next week. Once i'm back I can focus on what it would take to run at Bonneville.
The Following User Says Thank You to Frankencar For This Useful Post:
JethroBodine (07-13-2012)
Old 07-17-2012, 07:02 PM   #37 (permalink)
Diesel
Another update:
Installed Mercedes G500 headlights and clear inners this weekend.
Removed the stock lights:
Installed the Merc lights with some adapters I made:
Comparison:
And the final product:
The result is a much wider and more even beam pattern. the 50W HID's in the inner lights also make the high-beam performance scary good.
Old 07-18-2012, 10:57 AM   #38 (permalink)
Diesel
Installed a NEW chrome rear VW emblem. It has been NLA for a while now, I was lucky to find one. I also installed a Fiat Marea weekend estate rear wiper on a pre-89' wiper hub.
And I finally installed this:
It's a Seat Toledo Belly pan - needs some trimming up front to fit behind the bumper, but makes for a nice underside! And I can't believe how much quieter the car is now! Now it's just the sweet TDI 2.5" straight pipe exhaust note.
And finally the small plastic air channels that go in front of each wheel:
I'm hoping this improves FE a bit.
Old 07-18-2012, 11:57 AM   #39 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
nice looking ride .
People you need to remember that more power does not necessarily mean you would need bigger brakes. If you still drive only the same top speed as with old power. Or even if you drive faster you dont need them if you dont start racing it so making many hard brakes after each another...
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
Old 07-18-2012, 12:15 PM   #40 (permalink)
Diesel
Originally Posted by Vekke View Post
nice looking ride .
Exactly. The brake upgrade is for when I go driving like a hooligan.
