Old 07-12-2012, 04:43 PM   #23 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Originally Posted by ron View Post
as I recall , the underground house book circa 1970s says build a 12inx12in tunnel 100 ft long below the frost line and pull the house air through it,that should cool a 1000 sq ft home to 57* winter preheat or summer cooling you can use the same 20in fan and save all the complication of radiators and water,tubing etc.
The big issue that people have had with earth tubes like that is rodents, insects, mold, mildew and radon, you end up with a lot of basement like surface area that you are pulling air from while a radiator is very easy to keep clean and you don't have to worry as much about rodents moving in or a heavy rain storm causing it to fill up with water.
