Go Back   EcoModder Forum > AltModding > Saving@Home
Old 07-11-2012, 09:15 AM   #21 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
There is a house down the street that has a closed loop of PEX pipe coiled around the house below the frost line, the radiator from that is on the incoming fresh air from the air to air heat exchanger, the house is super insulated and it takes care of 100% of their cooling needs in the summer and preheats incoming fresh air in the winter.
Because it's a closed loop there is very little resistance other then that of the pipe for the pump to push, no head like you would have with a well, so it takes very little energy to keep the system going.
Old 07-12-2012, 02:39 PM   #22 (permalink)
ron
double eagles - '99 Dodge ram slt
90 day: 19.48 mpg (US)
as I recall , the underground house book circa 1970s says build a 12inx12in tunnel 100 ft long below the frost line and pull the house air through it,that should cool a 1000 sq ft home to 57* winter preheat or summer cooling you can use the same 20in fan and save all the complication of radiators and water,tubing etc. . It may be a good use for your new toybota
Old 07-12-2012, 03:43 PM   #23 (permalink)
Ryland's Avatar
The big issue that people have had with earth tubes like that is rodents, insects, mold, mildew and radon, you end up with a lot of basement like surface area that you are pulling air from while a radiator is very easy to keep clean and you don't have to worry as much about rodents moving in or a heavy rain storm causing it to fill up with water.
Old 07-28-2012, 07:14 AM   #24 (permalink)
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
We just dug a trench for electricity. Would have to agree that it would take a heck of a trench to dig a big loop outside the house for air transfer. It would be a monumental undertaking. Big expensive conduit.
I am sure that even if were sealed it would house all sorts of nasties after a few years. Bugs, rodents, mold and other filth that would be recycled. and impossible to clean out. Even a small leak allowing moisture in would likely bring in water which would compound the problem.
I like the original idea of pumping cool water through a radiator. It would still eventually clog up.
Nice tractor and Yamaha btw.
Noah Webster, 1787
Old 07-28-2012, 09:22 AM   #25 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
Why not put a little anti freeze, or similar in it?
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 07-28-2012, 02:44 PM   #26 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
While these cooling systems don't come cheap, putting them in place when the foundations are done, means the digging won't take very long when using a backhoe.
The air can be filtered at the intake, so the critters can't get in.
What is the best cheap car for Hypermiling? roadracer380 EcoModding Central 4 06-12-2010 01:50 AM
Good cheap project cars ebacherville Aerodynamics 13 05-08-2008 12:04 PM
Saving a few watts - a few ideas that I use around the house Lazarus Saving@Home 10 02-01-2008 07:13 PM
