Chris914, if you are still on the list, what was the angle of the plane from the roof to the decklid on the fastback model you tested? Most studies show ~12-15 degrees optimal with a big jump in CD starting at ~20+ on road vehicles.
I measured ~22 degrees from this blueprint which would make it too steep for good CD reduction. Perhaps a little less slope would have yielded better Cd reduction than the stock roofline.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
