Old 07-13-2012, 09:45 PM   #19 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
In many states you can register your car as a hot rod or kit car by basing it off a vehicle that is over 20 years old (1992) so an early metro XFI that is rusting out would be perfect! or a regular metro and put the xfi cam shaft in there.
When building a kit car one thing to aim for is basing it off a common car that has issues, like rust! then you use the good parts like doors, dash, suspension and build your car around that.
Honda Civics are another car to look at, a 1992 honda civic sedan or coup is going to sell for a low price if the wheel wheels are rusted out and Civic VX engines bolt in giving you an engine that gets great mileage then either bolt the electric motor in where the AC compressor would bolt on or have the electric motor drive the rear wheels using the drive train from a rear wheel drive or 4 wheel drive vehicle.
Basing your vehicle off as many stock off the shelf parts and stock junk yard parts as possible is going to make your job easier.
