Old 07-14-2012, 08:25 PM   #58 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Originally Posted by Allch Chcar View Post
You're probably running too lean. Add some gasoline and see if it runs better. Until then please take it easy.
It has been running better on the E85 the past few days. I'm thinking it may take a few key off/key on start-ups for the computer to re-calibrate for the different fuel.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
