Old 07-16-2012, 08:24 AM   #8 (permalink)
CapriRacer
Tire Geek
CapriRacer's Avatar
Originally Posted by niky View Post
Is that around 3% regardless of pressure? I mean, say, going from 30-40 psi? ..........
I KNOW that the difference between the measured diameter and rolling diameter is about 3% - at normal inflation pressures and loads.
I SUSPECT the difference in rolling diameter for different loads and inflation pressures is in the fractions of a percent - which is probably not enough to worry about.
CapriRacer
Visit my website: www.BarrysTireTech.com
New Content every month!
The Following User Says Thank You to CapriRacer For This Useful Post:
niky (07-16-2012)
