3.73 to 3.45 is about a 8% increase, you could get 15" tires larger or smaller than your current size. i dont know if $ wise it'll ever work out, changing gears and wheels, but if you can find a way to do it cheap enough, great. depending on other lowering options, i might look at how small of tires i would want to put on, effectively lowering the vehicle, and then compensate with even taller gears.
i had a 89camaro i swapped a 97firebird rear end and 2000 camaro wheels onto, when i was done, i just drove it on the interstate, cruise control set at a certain speed, timing between mile markers with a stop watch. calculated the % increase or decrease i needed only from speedo reading and timed mile, because my speedo was already slightly off before, and theres just less math to screw up.
know for sure there is a gear to change?
