Old 07-16-2012, 06:18 PM   #30 (permalink)
Varn
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
weather
I take strips (3"x18") of polyester or nylon cloth and cover the still wet carbon or fiberglass. They smooth the surface out and leave a finish that you can apply another layer if needed. You peel them off as the layup cures. Leaves no sharp edges.
As far as using the wrong hardener I have been there done that. Try using fast when the temps are over 90. Much worse.
Noah Webster, 1787
