Old 07-16-2012, 07:59 PM   #1 (permalink)
ConnClark
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Power generation & drag reduction (from "paddle wheel" mounted in rear turbulence)
Came across an interesting paper today that discusses power generation and drag reduction.
http://www.openfoamworkshop.org/2009...gnon_paper.pdf
USING OPENFOAM TO MODEL ENERGY TAKEN FROM THE SWIRL
BEHIND A CAR
Louis Gagnon
Marc J. Richard
Benoît Lévesque
Dept. of Mechanical Engineering
Laval University
Québec (Québec) Canada
Abstract. A two-dimensional numerical analysis of the Ahmed body was performed using the k-!-SST turbulence model
from the OpenFOAM software. The analysis was then modified to include a rotating paddle wheel that captures energy
from the swirl that forms behind the vehicle. The rotating wheel is modeled using a General Grid Interface (GGI) and the
energy captured is calculated with the help of the forces library of the OpenFOAM software. Power generation reached
16.1 watts at optimal conditions. Total drag reductions up to 8.2% were found. Most computations were run in parallel
on a dual core computer.
I don't know how well it will translate to real life but it is interesting.
The Following 4 Users Say Thank You to ConnClark For This Useful Post:
aerohead (07-17-2012), landsailor (07-18-2012), MetroMPG (07-17-2012), Ryland (07-17-2012)
