Originally Posted by MetroMPG
Civic folks correct me if I'm wrong, but you might want to avoid the SI since it has the shortest gearing (highest RPM/worst highway MPG at cruise).
Though the short gearing may make for better P&G results (faster acceleration/shorter pulses), if you're willing to use that technique regularly.
I believe you're right on the short gearing in the Si.
The [EDIT] EX has fairly short gearing, not HX [/EDIT], giving relatively high rpms.
From what I've seen, the HX and DX may have equally tall gearing, and probably also the less common CX also has tall gearing.
