Progress- Got the glow plugs wired, firing a 60 amp solenoid off the rear window heater switch
. Got the fuel pump wired to key switched power that doesn't disappear in start position. Got rid of the catalytic converter and installed the exhaust front to back. I am getting some leakage around the manifold to flange connection, will need to revisit once a couple other things are done.
To do- Still need to realign the crank pulley and fix the fuel leak around #1 injector.
Road test tomorrow.
The rest will be tweaking and "hardening" as aerohead said
